Results 1 to 6 of 6
    Nov 2006
    407
    Default home made purge block ideas
    guys,
    i searched and couldnt find many pics of any purge blocks on here.
    i will be practicing tig welding on stainless sheet metal and want to do it the correct way.
    i like to make my own tools when possible, and would like you to share any of your pics and ideas on how you made your purge blocks, or where did you buy them ?
    thanks in advance for any help you can offer.
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Nov 2006
    407
    i seen some a few years ago in a magazine. i think they were a thin box shape made out of copper with drilled holes throughout...and a fitting for the argon line..
    does this sound correct ?
    thanks
    SyncrowaveŽ 200
    PA
    378
    Here is an article by Miller on tig welding titanium but the techniques are applicable to stainless also.
    http://www.millerwelds.com/resources...tanium-welding
    Jan 2009
    SW Ohio
    135
    Quote Originally Posted by Burnt hands View Post
    The pieces in the second photo look a lot like the ones I've made for myself.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    PA
    378
    FABMAN,
    Here are 2 trailing shields I made.
    Quick and cheap to make for a one time job.
    Used fine stainless mesh for the gas diffuser and .035" stainless for the back. SS tubing is 1/4" diam.
    Next version will use stainless perforated metal with .033" diam holes.
    Jan 2009
    SW Ohio
    135
    FABMAN,
    I like the idea of using fine mesh ... thanks.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
