    Feb 2013
    Exclamation Preheating Prior To Welding Alloy Steel Pipe.
    Welding Alloy Steel Pipes Using GTAW 1/2" Pipes
    What is most convenient way to Preheat.?
    Which Equipments should be used to Measure Temperature.
    Please do the needful......
    Default Preheating Prior To Welding Alloy Steel Pipe.
    Oxy act and a temp stick
    Aug 2004
    Milan Michigan
    1,880
    If its big pipe you also might want to consider one of those weed burners hooked up to a propane tank provided your just trying to take the chill out of the pipe.
    Apr 2012
    Western Pa.
    328
    I use propane for Pre heat due to cost of acetylene. H/D weed burner for the big stuff or propane Rosebud tip on torch for smaller things.
    Use Laser Thermometer to read temp.
