Results 1 to 4 of 4
    May 2007
    Los Angeles
    135
    Default Reduce Post flow gas Maxstar 150sth??
    Is there anyway to reduce post flow on maxstar 150STH? i am wasting a lot of gas on random projects.
    Jan 2009
    19
    I believe it is pre set. How much do you think you are wasting? Post flow helps protect the weld as well as tungsten. I figure if it's gonna flow, its gonna flow on the weld where it will help.
    Oct 2012
    5
    I think the gas post flow is pre-set depending on the amps your running, the hotter you weld the longer the post flow. I have the same problem. Also does anyone have issues with weak HF?
    Aug 2004
    Milan Michigan
    1,798
    Turning down your CFH to a bare minimum will help.
    Sometimes when I'm tigging heavy pipe I actually wish it would stay on a hair longer so Miller had to meet in the middle so ya it stays on a little longer than need be when welding on certain things.
    Keep in mind I'm not complaing, Its a great machine.
