Results 1 to 8 of 8
    Rosetown, SK.
    514
    Default 212 Autoset Welder Quits After short welds
    Have a 212 Autoset welder with only about 1/4 roll of wire used since new last fall. Suddenly in mid to higher amperages it will only weld about 1" then cuts out. After a couple minute cool down it will weld again but only for a short bead. Anyone know what might be going on?
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Jan 2008
    northern california
    317
    Default voltage jumper
    Do you have the machine set at the proper voltage? Can be set at 208volts or 230-240volts.
    Ornamental fabrication shop worker
    at home...
    2011 Hobart Handler 210
    Rosetown, SK.
    514
    Trying to help another fellow who does not have a computer. He is going to check that for sure. Only problem is he said he has used it before & never had any issues like now.
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
    Rosetown, SK.
    514
    Talked to him & he checked. It is set on 230 volts. So what next?
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
    6,752
    Drive is too tight, best to loosen it untill the wire curles up nicely in the palm of his hand. More like the drive thermal is causing the drive to stop.
    Rosetown, SK.
    514
    Thank you cruiser & will get him to give that a try,Much appreciated
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
    Rosetown, SK.
    514
    Thanks for the replies & especially cruizer who nailed the problem for us. Drive rolls had too much tension & caused it to trip out. We have a happy customer now & thanks again to cruizer for the solution, much appreciated.
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
    Man that cruiser always gets it right
