    Feb 2013
    Kansas City, Missouri
    11
    Default flakey Syncrowave 200
    I have a Syncrowave 200 that is acting flakey on me. I am welding aluminum on AC 175A 7.5 balance. Sometimes the welder acts perfectly normal, other times I push the pedal, pre-gas starts, then I hear a hum but no spark. I let off the peddle and get post flow.
    Why no spark?
    What information have I left out?
    Thanks for your help.
    Chuck
    Aug 2010
    1,163
    Quote Originally Posted by ChuckS View Post
    Why no spark?
    Chuck
    First I would check your ground. Then I would rub the tungsten on the table before starting, as the tip can get glazed. Then I would check your point gaps.
    Good Luck.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2008
    113
    My old machine would do that with bad ground as well
    Feb 2013
    11
    Quote Originally Posted by mikesystem View Post
    Thanks for the ideas Guys, I will do me some ground checking.
    Feb 2013
    11
    Good Luck.
    Ding ding ding, we have a winner! Apparently vandals are breaking into my shop and contaminating my tungsten. Thanks for all your help, I was just sure it would be something major,since I bought this used with only 4 hrs on it.
