Thanks!
Results 11 to 20 of 27
Thread: how do my welds look?
02-11-2013, 07:47 AM #11
Member
- Feb 2013
- 74
02-11-2013, 02:14 PM #12
- Oct 2009
- 254
Material thickness and the joint configuration?
and wp2025 weldcraft torch
Miller 125c plasma cutter
02-11-2013, 10:29 PM #13
Member
- Feb 2013
- 74
I believe it's 3/8 and its just flat practice welds. Like line after line and practicing the over laps
02-11-2013, 11:07 PM #14
Member
- Feb 2012
- 85
Keep your speed more consistent and slow down just a bit.
02-12-2013, 10:32 AM #15
Member
- Feb 2013
- 74
Will do, thank you. I thought that I might be going a little fast and am tryin to work on makin everything more consistent so it'll look better
02-23-2013, 10:26 AM #16
- Feb 2013
- 11
Kiss
As others have said get comfortable. But before you lay your bead get into position and dry run your weld. Finding a comfortable spot that will let you weld all the way through without ending up in a funny position will help. Good luck and have fun
02-23-2013, 08:27 PM #17
- Jun 2009
- greenfield new hampshire
- 776
texas has a good point, what i see in your work is lack of planning, which is good, most beginners have many more issues, you seem to have the basics of the phyiscal part of it working for you, you need to plan for each inch of weld, for example, the left side of the plate looks far different than the rest, telling me, you could not see much and the rod angle was not correct, practice
02-23-2013, 10:22 PM #18
Member
- Feb 2013
- 74
Thanks guys, I've gotten a fair amount better since this post. I figured out about the getting comfortable and planning the weld. I used to always get hung up towards the end of the weld by having to get in awkward positions to finish it out but I'm getting better at that. Right now were doing 6011 filler joint, 3 passes on each side and I'm trying my best to get good at it. They don't look horrible, but I know I can do better if I practice. Thanks everyone for the tips and advice
02-24-2013, 09:19 AM #19
- Feb 2012
- illinois
- 12
beads
They look pretty darn good to me!
02-24-2013, 11:12 AM #20
Member
- Feb 2013
- 74
Thank you!
