Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Default how do my welds look?
    I just started welding about a month ago. Never welded a bead in my life before i took this class, but Im really liking it so far. Taking welding classes in trade school through my high school. This is horizontal stick with 6013. Any and all help would be appreciated and let me know what I'm doing wrong please. Thank y'all in advance
    Ill try to get more pics Monday of one of the better welds, these aren't my best but just the ones that I remembered to take a pic of.
    Well Dang, I guess no one has any input for me
    Jan 2013
    Nebraska
    15
    Not bad for just starting, keep practicing!
    Do you notice anything by just looking at it that I could improve on? And thank you
    Oct 2005
    North Central Indiana
    782
    I'm no expert, but it looks like you have some undercut on top, stay a bit longer at the top so you fill in the undecut or what's called washing in before you go to the bottom and wash in. Maybe count 1001 at the top of the weld each time or what ever group of numbers in sequence 1001 1002 1003 seem to give enough time to fill the undercut in before you go to the bottom and wash in. I can't tell for sure, but your heat looks to be a bit cold, try 5 amps more and be ready to move foward a bit faster. Play around with the amps/heat and foward travel speed. You'll get it, everyone does that's willing to suffer though the learning curve. Never ever give up!
    Jan 2013
    Nebraska
    15
    Just what I can see from the picture is work on being steady and you will have a straighter weld. That will come with more practice, main thing is just relax when your running your bead.
    Thank y'all, I can't really remember but I think I did turn my heat up after I took this pic. And I'm trying to keep more steady and get in a comfortable position to run the bead each time. I'm definitly goin to keep at it though! I'm really hooked now and hopefully ill improve a lot before the class ends!
    Jan 2013
    Nebraska
    15
    Your welcome! Keep at it!
    Jul 2012
    Houston,tx
    119
    Not too bad for a beginner
