any tips on welding bronze weldable hinges to aluminum post
Results 1 to 10 of 12
Thread: aluminum & bronze
02-09-2013, 10:31 AM #1
- Feb 2013
- 1
aluminum & bronze
02-09-2013, 11:08 AM #2
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
02-09-2013, 02:58 PM #3
Epoxy and then pray some more.
02-09-2013, 05:58 PM #4
- Oct 2009
- 254
Lol bolt them on
and wp2025 weldcraft torch
Miller 125c plasma cutter
02-09-2013, 06:42 PM #5
You got me very curious how this would work... I just welded a piece of BRASS to aluminum with bronze silicate filler. AC hf straight argon. I assume if the bronze in the filler with work then your bronze hinges will work as well
02-09-2013, 06:47 PM #6
Low fuming bronze does not work at all. Blew my cup into pieces soon as it touched
02-09-2013, 10:57 PM #7
- Sep 2009
- Colorado
- 148
Video on brazing aluminum
Kent white is a huge promoter of oxy-acetylene use, including welding aluminum. He comes out of the restoration world. This video shows brazing aluminum.
http://www.youtube.com/watch?v=RRWmpSE-hXk
The video does not say exactly what brazing rod he uses, but if you go to the tinman web site you should find it.
https://www.tinmantech.com/html/brazing.php
Richard
02-10-2013, 09:24 AM #8
- Oct 2009
- 254
Aluminum's melting point is 650 celcius while bronze is around 950 celcius depending on alloy makeup.
This doesn't help the situation. The only way I see you getting the two stuck together is using silfos but your still likely to end up with a mess rather than a brazed joint.Miller syncrowave 200 runner with coolmate 4
02-10-2013, 12:49 PM #9
- Jan 2013
- 27
aluminum and bronze welding
you got advice to bolt them and that is correct.
the reason is your trying to weld ferious metal to non ferious metal. that means carbon and non-carbon. . the key is they are not only different in structure but have different melting points. aluminun is strong yet it will, melt before the bronze.
so anyway thats that.
02-12-2013, 08:09 PM #10
Bronze is NON FERROUS. MADE PRIMARILY FROM COPPER ALLOY. THE DIFFERENT MELTING POINTS CAN BE HELPFUL SINCE HE WILL BE PERFORMING A LAP WELD.... THE TOP PIECE "bronze hinges" ON A LAP WELD WILL TYPICALLY BURN BACK FASTER SO AS I SAID.... THAT MAY HELP THE WELDING PROCESS.
Originally Posted by welding insp.48:301706
