Results 1 to 10 of 12
    Feb 2013
    Default aluminum & bronze
    any tips on welding bronze weldable hinges to aluminum post
    Aug 2010
    1,170
    Quote Originally Posted by weldumup View Post
    Pray.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2004
    Milan Michigan
    1,811
    Epoxy and then pray some more.
    Oct 2009
    306
    Lol bolt them on
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Sep 2012
    seaford de
    407
    You got me very curious how this would work... I just welded a piece of BRASS to aluminum with bronze silicate filler. AC hf straight argon. I assume if the bronze in the filler with work then your bronze hinges will work as well
    Sep 2012
    seaford de
    407
    Low fuming bronze does not work at all. Blew my cup into pieces soon as it touched
    Sep 2009
    Colorado
    225
    Default Video on brazing aluminum
    Kent white is a huge promoter of oxy-acetylene use, including welding aluminum. He comes out of the restoration world. This video shows brazing aluminum.
    http://www.youtube.com/watch?v=RRWmpSE-hXk
    The video does not say exactly what brazing rod he uses, but if you go to the tinman web site you should find it.
    https://www.tinmantech.com/html/brazing.php
    Richard
    Oct 2009
    306
    Aluminum's melting point is 650 celcius while bronze is around 950 celcius depending on alloy makeup.
    This doesn't help the situation. The only way I see you getting the two stuck together is using silfos but your still likely to end up with a mess rather than a brazed joint.
    Lightbulb aluminum and bronze welding
    you got advice to bolt them and that is correct.
    the reason is your trying to weld ferious metal to non ferious metal. that means carbon and non-carbon. . the key is they are not only different in structure but have different melting points. aluminun is strong yet it will, melt before the bronze.
    so anyway thats that.
    Sep 2012
    seaford de
    407
    Quote Originally Posted by welding insp.48:301706
    Bronze is NON FERROUS. MADE PRIMARILY FROM COPPER ALLOY. THE DIFFERENT MELTING POINTS CAN BE HELPFUL SINCE HE WILL BE PERFORMING A LAP WELD.... THE TOP PIECE "bronze hinges" ON A LAP WELD WILL TYPICALLY BURN BACK FASTER SO AS I SAID.... THAT MAY HELP THE WELDING PROCESS.
