There seems to be a lot of concern about your grinding but if I understand it correctly, you're lacking filler material. You either need to make another pass or two or use a weave on the top weld so that there is sufficient material to fill the void.
Results 11 to 17 of 17
02-08-2013, 06:19 PM #11
- Jan 2012
- 28
02-09-2013, 06:23 AM #12
- May 2012
- 106
Hey Joe! Was looking for your input! I was only thinking a root of 6010 as that is what I've been taught as standard practice for structural joints - with 6010 to get 'better penetration' thus used as the root. But I wasn't sure it was necessary - or if it differs from a butt joint to a fillet weld joint. I think I might forget about the 6010 and just run a couple 7018's - it'll be easier for me!
Miller Thunderbolt 225 AC/DC
Millermatic 211 Auto/MVP
02-09-2013, 07:03 AM #13
Bevel both sides & weld with 7018 will be fine. If you positively need 100% penetration then after welding the first side root, flip it over & grind out the second side till your into the first weld. Then weld it up alternating sides to minimize pulling.
The real question you need to figure out is why did it break in the first place? If this isn't fixed then it will most likely fail again unless it was a one time incident that doesn't normally occur.MM250
RCCS-14
02-09-2013, 11:20 AM #14
- Feb 2012
- Wa
- 320
Flap disk for sure. Impossible to have the control with an abrasive grinding wheel. I like norton multi flaps.
02-09-2013, 01:09 PM #15
I disagree with the grinding wheel comment. I've done hundreds of machine bases over the years where all outside seams had to be ground flush. 7" type 28 wheel followed by a 36 grit sanding disc. This is the fastest we found. It's in the technique. Most newbies tend to dig & leave a valley.
http://www.mcmaster.com/#type-28-gri...wheels/=lenkx2
http://www.mcmaster.com/#standard-sanding-discs/=lenlbjMM250
RCCS-14
02-09-2013, 05:00 PM #16
- Feb 2012
- Wa
- 320
02-10-2013, 10:37 AM #17
MMW, You are dead on, Not enouph filler metal.
Thats one of the first things I have to teach a guy before I turn them loose with a grinder on a hand rail.
You need to keep the grinding wheel on the weld and keep the grinder relatively flat.
I can seem a pipe together and you will never find my weld, keep the ginder flat and on top of the weld.
However all that is useless unless you have enouph filler metal.
