Results 1 to 10 of 11
    turbo38t Guest
    Default Soda can welding....
    I was tinkering with this last night and would like to some more. I was able to get the cans joined and some filler in there but the problem was contamination. What's the best way to cleann the cans? I used coke zero cans and a wire wheel to remove the coating. I think a chemical would do it better? Was very difficult to establish a "clean" puddle. Dave
    Feb 2012
    wisconsin
    116
    There are a couple youtube videos you can watch.
    The inside of the pop cans are coated also, its very had to get a contamination free weld with pop cans
    Dec 2008
    Arizona
    812
    You'll have better luck with beer cans. Once you empty enough of them you won't care anymore!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Feb 2013
    10
    Probably best off with the brush. The chemical you would need to get that coating off would be pretty "heavy duty" and probably hard to find. Think about how corrosive coke is. At our fire department we use it to clean blood and oil off of the roads after a car accident, works better than you think
    Frank
    northern NJ
    1,914
    Smile
    Your asking in the wrong place. You need to ask the guy at the flea market with the special aluminum rods.
    MM250
    RCCS-14
    Mar 2012
    9
    I welded some DP cans, the coating inside causes a problem, if you can get a clean drop of weld started, you should be able to get around it.
    http://mob854.photobucket.com/albums...dpopcan003.jpg
    Feb 2013
    1
    Default Pop Can welding
    Hi You can weld two pop cans together with TIG. Turn down your amps as low as you can and use pure argon. weld them bottom to bottom. Clean with a new wire brush and only use it for aluminum. Clean with acetone. Post the picks on here when your finished. Visit youtube or visit weldingtipsandtricks.com Jody is a great goto with questions and has a ton of videos.
    Aug 2004
    Milan Michigan
    1,833
    At $ .10 a peice I find that its way easier to throw them out than to weld them.
    Aug 2010
    Los Angeles
    1,178
    I used a scotchbrite wheel and then acetone, which worked great.
    I also tried a wire wheel and it embedded paint deep into the surface.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
