Results 11 to 20 of 20
    8,225
    Whats the DC+ OCV now??
    Oct 2012
    17
    DC+ voltage at 28.3v at run position OCV
    8,225
    whats the AC output at the studs in dC+ mode. I'd say that your rectifier is pooched.
    Not usually a winding issue.
    Oct 2012
    17
    The DC+ AC voltage is 11.8V at run speed.
    If it is the rectifier, any way to repair a rectifier without purchasing a new one from Miller?
    Oct 2012
    17
    BTT
    Anybody know how to test the rectifier?
    Oct 2012
    17
    Bump. Anybody have a test procedure for the rectifier?
    Oct 2012
    17
    OK. Replaced rectifier with new rectifier from Miller. Still no weld output.
    Where do I start looking next?
    8,225
    Tough one to online T-shoot, best take it into a qualified Miller repair center
    Oct 2012
    17
    I know it is tough online, and I appreciate your help very much. I just like working on them to learn a little before giving up too fast. I switched the C1 cap from another machine, no change. Fuses good, C1 Cap is good, Rectifier good, AC output OK....I feel like I'm down to the Integrated rectifiers or the Reactor
    I want to check the integrated rectifiers SR2 and SR3. What should I be looking for and how do I test them?
    8,225
    Best to us a diode test function on a meter. point ot point on the 4 terminals, will either be open (OL) or have a reading around 0.5Volts
