    Feb 2013
    Default Millermatic Argon inlet CGA #
    I would like to know what the CGA # is on the back of my MM252. I have a dual cylinder rack, and would like to connect a "Y" fitting to feed both tanks into machine as needed (obviously, not at same time)
    Does anyone know what the CGA # is?
    3,951
    Don't know of a number but its either 9/16-18 or 5/8-18 thread can't remember which....Bob
    2,936
    Dec 2012
    64
    I plan to add another identical solenoid gas inlet valve to my 211, and a clamp w/o wire feed drive to the front for the spool gun, and another port for the control connector, then rewire the new connector to trigger the new valve so I can leave the spool gun & both bottles connected all the time. I'll notch the spool gun case so the gun can stay inside while connected. I just don't know where to get the clamp w/o motor, or if I'll have to make that.
    Cave Creek Az
    1,052
    Quote Originally Posted by Steve83 View Post
    Wow, what an incredible amount of work. It would be a lot cheaper to add quick disconnects to you regs. Even better to have bought a machine with gun on demand.
    Dec 2012
    64
    Disconnecting is exactly what I don't want to have to do. And the 211 is the machine I wanted - it just needs a few little tweaks, but I have the time to do them. I don't expect to spend much. A valve is only ~$35.
