Results 1 to 10 of 18
    Feb 2013
    8
    Default Blowing TIG hoses
    Anyone have issues with their TIG powerlead blowing holes near the machine, spewing coolant everywhere? Just breached my fourth hose in two weeks, no idea whats going on. Cleaned the coolant strainer, going to pull the whole reseviour/ radiator today to clean, troubleshoot. Been running pretty high amperage lately but never had a problem with it before. Syncrowave 250DX/CK200/CK300
    Not stoked! Any help will be much appreciated, thanks.
    Aug 2010
    1,099
    Quote Originally Posted by metalslayer View Post
    Obviously you have a blockage or motor stoppage.
    Check the flow coming out of the torch, and consider putting Ck fuseblocks on your power cable in case of motor stoppage.
    My guess is your motor is overheating and the thermal overload switch is tripping leaving an air pocket in your power cable because coolant is not flowing.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    6,752
    That or you have them hooked up backwards which is more likely. Both waters have the same thread, though one is high pressure and one is drain. If you get em backwards. the hoses will blow...
    Feb 2013
    8
    Hoses are hooked up correctly, one is reversed thread. I've been running this machine for over two years now and just started seeing this issue. Weird.
    Oh, whoops. I see what you mean. Yes both are threaded the same, and hooked up correctly... thanks.
    Feb 2013
    8
    How would you suggest I check the flow, unplug the return and turn the machine on? Not sure..
    And how can I confirm the motor is over heating?
    Thanks.
    Aug 2010
    1,099
    Thanks.
    You could unscrew the big power cable nut at the machine, and turn on.
    The only way to confirm if the pump motor is overheating is to watch for it. Are there fan louvers to tape strands of paper over?
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Aug 2010
    1,099
    I always wondered about that.
    Why would they blow?
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Aug 2008
    103
    I could not see why it would blow if it was backwards flow is flow right ? As long as it don't stop ? Sorry to jack your thread
    Oct 2009
    254
    Unhook the return at the cooler and turn it on with the return held over the refill on the cooler. If its slow something is restricting flow. I've had coolmate 4's oxidize the copper heat sinc tubing inside and flake off which reduced flow considerably, have also had algae build up do the same thing
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Aug 2008
    103
    Jrscgsr has that happened to your coolmate ? When I first hooked mine up I did the same thing as jrscgsr said with return line and see what happens should work like a dream on the other hand I have seen some pretty dirty coolent before I had melted one line my self and
Tags for this Thread
