Results 1 to 10 of 14
Thread: welder problems
    Default welder problems
    I have a maxstar 200 sd and a dynasty 200 dx and I have installed a 220 outlet in my garage. it is the style of outlet that a lot of dryers use - 4 pin. when i plug in either welder and turn them on they make a weird noise buzzing type, and the number -2 flashes on the display. I have already toasted one power inverter. I am not sure what is going on
    alabama
    717
    while a very light sounding hum is normal a help 2 is not. Did you use the red wire by chance?
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    not sure what you mean the red wire. in the plug i connected the red, black, green, and white wires to their terminals. the noise is very loud and not normal and continues after it is turned off unplugged and then slowly dies down until it stops.
    Jan 2008
    northern california
    317
    Default what happend to the owners manual?
    You are not supposed to use the red wire. That is for 3 phase!
    Ornamental fabrication shop worker
    at home...
    2011 Hobart Handler 210
    Feb 2006
    Northern CA, Shasta CO.
    134
    Very important question, do you actually measure 230V/240V across the two designated hot leads of the receptacle you put in?
    2,636
    Quote Originally Posted by desertranger View Post
    As mentioned the red wire on the welders is for 3-phase power
    Since you are using it on Single phase you only use the black,white and green wires.
    The 4-wire receptacle you have is a single phase 120v/240v circuit: 120v for lights, timers on the dryer and 240v for the heating elements.
    On the Dryer plug in this application for the welding machine you Only use the 2 straight blade and rounded( ground) terminals NOT the L shaped terminal.
    The white and black can go either straight blade
    i have hooked up the plug as directed with three of the four terminals without the red wire. I is doing the same thing. Will hooking up all the wires on a single phase source damage the welder ? Any one know what the -2 means ? When I turn it on the first thing it displays 243 891 then -2 and right display is blank. then it goes to the normal operating display.
    6,752
    Time for an electrician, cause what you've done is entirely stupid, no wonder why you've roasted machines.
    UNPLUG EVERYTHING and phone up someone who has a clue!!
    Feb 2013
    9
    Sounds like you might have hooked up the power in your shop incorrectly, but I have no idea.... The red wire is only used for three phase , that's all I know.
    the power in my garage is fine. at the time i did not realize the plug configuration was different for single and 3 phase. now i see my mistake.
