Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Jan 2012
    28
    When say "lighter", I'm only talking 1/8" material. I amusing the recommended settings for 3/16 material. Fwiw its a Miller 252.
    Oct 2009
    306
    Throw up some pics of the part and we can tell you exactly what's going on with the weld.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Jan 2012
    28
    I guess maybe for tacking. But not for running a real bead.
    Why not ?? Different gauges of metal are joined together every day. Generally the higher setting of the two is used with most of the heat aimed towards the heavier gauge.
  4. #14
    Apr 2012
    Western Pa.
    293
    Default Mig cold joint??
    Yep. I agree.
  5. #15
    Jul 2012
    Liberty, Mo.
    64
    We really would have to see the weld joint(s) to really know what the complainers are referring too. Sometimes, you can have a weld with decent fusion but if the weld is really tall it is considered "cold" as well. Causes range from slow torch travel speed, wire feed too excessive, not enough power etc... Perhaps strive to make the weld no more than 1/16" thicker than the material depending on the type of joint. That may mean beveling out the joint or creating a "gap" depending on the thickness and if your welder is not able to make the weld in a single pass.
