Results 1 to 10 of 15
    Jan 2012
    28
    Default Mig cold joint??
    What does a mig "cold joint" look like?
    May 2012
    chilliwack BC
    38
    Prob has snow or ice on it. ;-)
    Jan 2009
    19
    [SUB[/SUB]
    For starters, look at the toes of the weld.
    Also, what type of joint in particular: lap, butt, etc?
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    If I am correct, I think you are referring to "cold lap" or properly called incomplete fusion. It is a common problem in mig welding and can be on the underside of the weld or on the leg or toe of the weld. Obviously, if it is on the underside you can't see it. But if it is on the leg or toe, it will look like the weld is just laying on top of the base metal not really fused together. Kinda hard to visualize until you actually see it. Will try to find a picture and post it for you.
    It is usally caused by trying to weld too thick of base metal without some preheat or an incorrectly adjusted machine. It is also a very big problem when mig welding aluminum.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Jan 2012
    28
    Most of the joints would be fillets.
    I've taken mig courses and have been mig welding a long time but I'm not a "professional welder" in that I don't weld for a living. However, I weld a lot - way more than the average hobbyist and I get a lot of positive feedback on my skills. I manufacture a product which I sell mostly at car shows and swapmeets.
    Here's the dilemma ...
    On two occasions I've had people tell me "there are some cold joints there" but they've never actually pointed them out. The only thing I can see is that on some welds the surface of the bead is not "shiny". Otherwise, they all look pretty much the same to me. In 5 years of making this product I've had nothing but positive feedback from customers and not a single mention of a broken joint. And many of my products have been sold to fabricators who've felt building the product was not worth the effort versus buying mine!
    I will point out that I weld mostly 3/16 material but there are some lighter gauge pieces that I attach without changing the settings. But I can't see this causing cold joints.
    Could it be, as one observer pointed out when someone made the comment, that "some people just need something to complain about" ?
    Wa
    628
    Well if you can use the same settings for 3/16ths on thinner material successfully, that makes me think it might not be hot enough for the 3/16ths.
    Post a pic
    S.W. Missouri
    155
    gkent, Here is a good example I ran into on a combine bracket.
    Trailblazer 302
    Lincoln SP-135-T
    Hobart Stickmate AC/DC
    Smith torch
    Spoolmatic 30A
    Apr 2012
    Western Pa.
    297
    U may hv hit the nail on the head ^ . And
    Jpence38 had pretty good explanation.
    But it pretty hard to get a cold weld on 3/16 metal with out it looking pretty bad.
    With that thin of metal if the weld looks good it's probably fine. Dull or shiny isn't a problem & the lighter metal at that setting should be a problem
    Apr 2012
    Western Pa.
    297
    Dull or shiny isn't a problem & the lighter metal at that setting shouldn't be a problem.
    Sorry mistyped:
    Shouldn't !! Be a problem.
    Wa
    628
    Quote Originally Posted by gnforge View Post
    Sorry mistyped:
    I guess maybe for tacking. But not for running a real bead.
