The project I'm doing is TIG welding two 3/8" mild steel square bars on an angle to a 1/2" square bar. The drawing is easier to understand than my explanation. Top bar only is illustrated.
the right angle pipes/angle iron, c-clamps, and vise grips I'm using for a frame just don't get the angles right.
Could I safely use modeling clay or something like that to hold small pieces at an odd angle just to get the tack weld made as long as I keep the clay away from the weld?
Results 1 to 10 of 12
02-04-2013, 09:16 PM #1
- Sep 2012
- 4
need tip on how to hold pieces for TIG at odd angle - ?modeling clay?
02-05-2013, 07:02 AM #2
- Oct 2006
- Illinois
- 458
Would these help ? Posting from another site.
http://weldingweb.com/showthread.php...ht=weld+finger
Mine is post #7, i think this will work . Various ideas shown.
02-05-2013, 09:37 AM #3
Member
- Feb 2009
- 93
I use these,bigger than they look.
Called a snake magnet.
http://www.summitracing.com/parts/vt...FQWonQode2QArQ
02-05-2013, 09:39 AM #4
Member
- Feb 2009
- 93
I use these, bigger than they look.
Snake magnet.
02-05-2013, 12:12 PM #5
- Apr 2009
- Upstate SC
- 129
I don't believe that welding finger will help much in your case. If you have a lot of them to make, you should make a jig. If it's just the one, I usually just grind the angles I need and hold them together by hand for a tack. Then you can bend them a little to get the final angle and weld.
You've got a tough problem, I admit.
CGOld Miller Swinger 180 Buzzbox
Miller Diversion 165
Smithy Lathe/Mill
02-05-2013, 08:05 PM #6
- Jun 2009
- 2
This universal clamp may be just what you need.
http://www.metalmeet.com/forum/showthread.php?t=7273
Don
02-05-2013, 10:10 PM #7
- Sep 2012
- 4
02-06-2013, 07:10 AM #8
- Oct 2006
- Illinois
- 458
The washer is a shade larger then the material that it slides on. It just binds on the round stock by gravity being on a angle. Your washer inside diameter maybe too large. You could try a small '' C '' clamp or baby vise grips on shaft to hold weight too. Hope it works.
02-06-2013, 04:26 PM #9
- Sep 2012
- 4
here's a solution I found
I looked around other forums and eventually was led to this youtube video.
http://www.youtube.com/watch?v=OnpOa...0A5051&index=2
pretty cool solution that would find many uses.
02-06-2013, 11:28 PM #10
