Page 11 of 17 FirstFirst ... 678910111213141516 ... LastLast
Results 101 to 110 of 168
  1. #101
    Jan 2013
    NE Illinois
    155
    Unhappy
    By the way, for anyone interested, the label on the MM200 says "assembled in the USA".
  2. #102
    Jul 2012
    Houston,tx
    119
    Default Miller Multimatic 200
    Have you usted the tig function homer
  3. #103
    Jan 2013
    NE Illinois
    155
    I tried it out last night for a few minutes. I didn't really have any scraps that I could use. First time I used lift-arc. Seemed to work pretty well.I got some 1/8 steel today so I'm going to try again this afternoon. I found the Weldcraft AK2 tig accessory kit on Ebay for $25. We'll see what it looks like when it gets here.
  4. #104
    Jul 2012
    Houston,tx
    119
    Ok keep me updated according to tracking # multimatic should be here Friday afternoon
  5. #105
    Jan 2013
    NE Illinois
    155
    Spoolmate 100 arrived this afternoon. Hooked it up, loaded it and tried to run some beads on some scrap 1/4" aluminum I have. Didn't work worth a ****. The Hobart Spoolrunner I had for the HH210 ran great so I was wondering why I couldn't get a good bead going. I checked everything, pre-heated the aluminum, cleaned it, etc., but still no luck. The gun kept sputtering and popping and the wire seemed to melt before it got near the aluminum. Then it dawned on me...with the Multimatic, you have to enter setup and calibrate the spoolgun. I did both the 100ipm & 300ipm tests. After some minor adjustments I got it dialed in. Tried another bead and...much better. Not perfect yet, but part of the problem could be that I had it on auto-set and it only goes up to 3/16" for aluminum. I tweaked the voltage & wire speed and it got a little better. I probably should have turned the auto-set off and just tried to dial it in manually. I'll try that tomorrow or Friday. It did run much better though after calibration and a little adjustment.
  6. #106
    Jul 2012
    Houston,tx
    119
    Real nice
  7. #107
    Jul 2012
    Houston,tx
    119
    Looks like in getting more ad more anxious by the minute
  8. #108
    Jan 2013
    NE Illinois
    155
    I know how you feel. It will be worth the wait though...
  9. #109
    Jul 2012
    Houston,tx
    119
    If you know anyone selling a miller suitcase 12vs let me know I'm looking for one
  10. #110
    Jan 2013
    NE Illinois
    155
    That's probably going to be pretty hard to find isn't it?
