Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Feb 2013
    27
    The CE model is PC7 . . 235 476 The US Model is . PC7 . . 233 144
  2. #22
    Feb 2013
    27
    I was finally home enough time to check the welder as requested. The results are below:
    RC1-1 to RC1-3: 321VDC stable
    RC2-1 to RC2-2: 0 volts pedal up or down
    RC2-1 to RC2-2: Frequency is unstable when pedal is down and reads in the Mhz (most likely induced voltage from RF)
    During testing the HF worked intermittently and gave both a very strong and sharp crackle while other times giving about a half crackle, DC voltage never showed on the RC2-1 to RC2-2. I wore rubber linesman gloves and welding gloves and wiggled the RC2 and RC1 wires while depressing the pedal. That did not change my results.
    Cruizer... what do you think we should do now?
