Results 11 to 20 of 22
    Feb 2013
    27
    Default Back In Town... Second Issue...
    I bought a 6/3 power cord because I noticed the unit didn't have a pig tail attached. I opened the top of the box and the manual to go with the welder. It looks like the welder is supposed to be shipped with a pigtail already wired into the welder. Most obviously it would hook to the back of the switch....
    So the 700 series power cable instructions say to use the top two poles on the switch for single phase. But those are the push in and screw clamp connections. The 350 uses spade terminals.
    Is the 350 the same as far as connection location goes? I will be using it single phase.
    Feb 2013
    27
    Default Cruizer maybe you can help?
    Ok... I finally got the machine hooked up. For those of you who requested the usage stats they are - 415 hours and 135308 cycles.
    I completed a factory reset per the owners manual.
    Today I tested both AC and DC and found them to be functional using the Lift Arc method.
    I checked and cleaned the HF points and set them to .010. HF did not work at all no matter the pedal position or AC/DC. What is my next troubleshooting step?
    Oct 2004
    Edmonton, Alberta
    8,097
    Because the HF worked but was erratic, I'd say that PC-7 is pooched.
  4. #14
    Feb 2013
    27
    The HF never worked for me but the seller claimed that it is intermittent. Do you have any troubleshooting guidance for PC7? That is a $500 part and I'd rather change components if I am able to source them. I am comfortable soldering and testing components as directed.
    Does anyone have a schematic for the PC7 board?
    Thanks!
  5. #15
    Oct 2004
    Edmonton, Alberta
    8,097
    I appear to be the only one with that info, but it won't help you.
    Only 2 checks to make
    RC1 check for 325Volts bewteen RC1-1 to RC1-3, unit on at idle
    RC2 check for +15 volts between RC2-1 to RC2-2 HF off
    Check for 0 volts HF on
    Or 700HZ betwwen RC2-1 and RC2-2 HF on
    If that is there, all is happy and you need a new PC-7 Replacing parts on this board is probably NOT a good thing. as it may dynamite the rest of the machine.
  6. #16
    Feb 2013
    27
    cruizer - Thank you for responding!
    I will check those voltages this weekend (hopefully). Right now I'm out of town for work. Please confirm with welder on and set to HF start mode:
    RC1-1 to RC1-3 voltage at idle is 325V AC or DC?
    RC2-1 to RC2-2 should +15 VDC pedal up?
    RC2-1 to RC2-2 should 0 VDC pedal down?
    I don't have a scope right so I can't check the 700Hz now but I can buy a scope if need be. I'd rather invest the $500 in a scope and fix the card for $15... but I will take your advice as we work through this. Thanks!
  7. #17
    Oct 2004
    Edmonton, Alberta
    8,097
    Whoops, yes DC volts
  8. #18
    Aug 2010
    Los Angeles
    1,170
    Just to rule this out.
    I had a 350DX delivered that would only work on lift arc. It turned out to have a Canadian board in it instead of the USA board. When the correct board was installed it worked perfectly.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  9. #19
    Oct 2004
    Edmonton, Alberta
    8,097
    Ummm, Canadain boards and US boards are the same.... CE (european) boards are different.
  10. #20
    Aug 2010
    Los Angeles
    1,170
    Perhaps that was what it was then. A call to Miller confirmed it though. The new board cured the start problem.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
