Results 1 to 9 of 9
Thread: magnisium
    Mar 2009
    kingsport tn.
    48
    Default magnisium
    need a little info. on welding magnesium. got a transfer case with pin holes it's magnesium thanks for any info.
    Oct 2009
    306
    Same as aluminum. Use magnesium filler
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Nov 2012
    4
    Default magnisium
    Any chance this is the chevy pump rub issue? If so i got mine fixed just with some jb weld and a spacer plate. Been solid for over a year now
    Nov 2012
    Northern Arizona
    538
    Quote Originally Posted by mike7466 View Post
    Did you do the merchant auto kit? How bad of a leak did your case have? Do you actually have to remove the case from the truck because it won't clear the crossmember that is right behind it? I've got an 06 lbz and I'll need to do this soon...
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Mar 2009
    kingsport tn.
    48
    yea a guy brought it 3 bb size holes at out put shaft side in the locking notch's said chevy would not honor the fix. yeah has to be out to fix to clean oil out heated it with a small propane torch and wire brushed it clean welded good
    Dec 2011
    418
    Is there room to tap the holes and put screws in? Could save a lot of work if it can be done.
    Meltedmetal
    Nov 2012
    4
    Default magnisium
    I believe the mechanic did pull the case off. Had to to intall a spacer plate inside so it quits rubbing. Mine was caught during an oil change and it must have just poked through. Maybe a diameter of 1/8 if that.
    Jan 2009
    SW Ohio
    135
    The cheapest magnesium filler I could find was $85 for a half pound from McMaster-Carr.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    Mar 2009
    kingsport tn.
    48
    air gas was 97.00 for a #1 (minimum 12#) went to a shop and a great guy gave me 2 stick's
