Im welding 2" sch 80, 6G Position
I seem to be having trouble keeping the key hole, not in the terms of loosing it but it gets away on me!!(too large)
I am using 1/8 6010 running about 85 amps with the arc force up too stiff on my
TB 302.
PIPE is set with 1/8 gap,1/16 root face, I have tried whipping and just shoving the rod in, It makes a perfect hollow pipe hiss but all of a sudden boom large key hole!
Going to try a feather edge and drop my amps too around 75,and set arc force to soft to see how that goes!!
Any and all suggestions/Tips will be appreciated,
Results 1 to 6 of 6
Thread: pipe welding help/suggestions
02-01-2013, 09:16 PM #1
- Mar 2010
- Ontario
- 154
02-01-2013, 09:27 PM #2
Try closing the gap down to about 1/16.
02-02-2013, 05:49 AM #3
- Mar 2012
- 10
I try to use 3/32 gap and turn your amps down that's a little pipe
02-02-2013, 06:42 AM #4
Member
- Dec 2012
- Simcoe Ontario
- 47
I always do heavy land like 1/8+ and 3/32 gap and crank the heat up to like 90-100 ish and get moving. If you try a feather edge it will just blow open faster. Unless you try feather edge and tight together. Play with gap ,face and heat till you like it
02-02-2013, 12:57 PM #5
Member
- Dec 2008
- Peace River,Alberta,Canada
- 63
Your gap and land is way out. 1/16 gap and a 3/32 land about 80-90 amps arc force 60%.
Push the rod in and drag it up little to no key hole.that will give you excellent results the rest is left up to your skill as the welder , rod angle pressure on the rod etc. hope this helps you out.
02-02-2013, 01:45 PM #6
- Mar 2010
- Ontario
- 154
Thanks everyone,, I tried a few different things this morn,, I also realized that the sch 80 pipe I bought and made into coupons is only 1/4" thick, not 3/8" like it is suppose to be,, also the bevel is a little sharper than the heavy wall...But not a excuse.. i ran root at 65 amps,arc force at 50% and 7018 at 95 amps arc force at 25% seemed to go ok,,,, all 1/8 elctrodes would like to use 3/32 for that small pipe but test calls for 1/8
I do however have one TSSA coupon, so I will give it a try at 80-90 amp and 60%arc force,, those settings are where i like to be....
I also did a few with tig root and tig all out,, they went flawless!
The Tig off the TB I think is great,,, My opinion only!!
