    Mar 2010
    Ontario
    154
    Default pipe welding help/suggestions
    Im welding 2" sch 80, 6G Position
    I seem to be having trouble keeping the key hole, not in the terms of loosing it but it gets away on me!!(too large)
    I am using 1/8 6010 running about 85 amps with the arc force up too stiff on my
    TB 302.
    PIPE is set with 1/8 gap,1/16 root face, I have tried whipping and just shoving the rod in, It makes a perfect hollow pipe hiss but all of a sudden boom large key hole!
    Going to try a feather edge and drop my amps too around 75,and set arc force to soft to see how that goes!!
    Any and all suggestions/Tips will be appreciated,
    Jan 2008
    Northern California
    20
    Try closing the gap down to about 1/16.
    Mar 2012
    11
    I try to use 3/32 gap and turn your amps down that's a little pipe
    Dec 2012
    Simcoe Ontario
    47
    I always do heavy land like 1/8+ and 3/32 gap and crank the heat up to like 90-100 ish and get moving. If you try a feather edge it will just blow open faster. Unless you try feather edge and tight together. Play with gap ,face and heat till you like it
    Dec 2008
    Peace River,Alberta,Canada
    63
    Your gap and land is way out. 1/16 gap and a 3/32 land about 80-90 amps arc force 60%.
    Push the rod in and drag it up little to no key hole.that will give you excellent results the rest is left up to your skill as the welder , rod angle pressure on the rod etc. hope this helps you out.
    Mar 2010
    Ontario
    154
    Quote Originally Posted by maharg View Post
    Thanks everyone,, I tried a few different things this morn,, I also realized that the sch 80 pipe I bought and made into coupons is only 1/4" thick, not 3/8" like it is suppose to be,, also the bevel is a little sharper than the heavy wall...But not a excuse.. i ran root at 65 amps,arc force at 50% and 7018 at 95 amps arc force at 25% seemed to go ok,,,, all 1/8 elctrodes would like to use 3/32 for that small pipe but test calls for 1/8
    I do however have one TSSA coupon, so I will give it a try at 80-90 amp and 60%arc force,, those settings are where i like to be....
    I also did a few with tig root and tig all out,, they went flawless!
    The Tig off the TB I think is great,,, My opinion only!!
