Results 11 to 13 of 13
    7,670
    Very unlikely its a Serial# HK, as these units were not around then, perhaps a KH sounds better.
    As I said, if the top board fails, its like $700 to buy a replacement. Best to merely send it out to a repair shop. which would cost around the $300 mark
    Feb 2013
    10
    Brought the machine to a new shop, they replaced the high frequency transformer in the bottom of the unit. They said that there was a pinched wire and when the frequency spiked it would arc across the windings. took the machine home and no change.
    Would love to solve this problem as right now I have a $1800 piece of garbage sitting in my shop
    Frank
    Feb 2013
    10
    2 different shops have now gone through the machine, both have said that the board is fine but said that a replacement isn't made anymore
