Hello,
I have a xmt 304 welder that I bought in the middle of summer, unfortunately i bought it used and it only cam with a 3 month warranty. I am having intermittent problems with the machine when I turn it on. At first tt my house I got a Help 6 code maybe once out every 10 times I turned it on. Now I only works once out of every 10! I have a project truck that I am working on at a friends house and we wired up a plug there, maybe 2km from me, and I get a help7, and sometimes a help0. But again will work maybe every 10th time you turn it on. I live in the country so the power isn't as perfect as in the city but at my house I have measured 239 and received a help 6 and up the hill measured 248 and got help 7. Is the welder really that sensitive? from what I understand in should have a 15% variance before it sends out a help code... And what do you make of the help0 code? I found a manual that stated that this could mean a burnt out thermistor, but then why does this only happen sporadically.
Thanks for any help
Frank
Results 1 to 10 of 13
Thread: XMT 304 Problems
Hybrid View
02-01-2013, 05:27 PM #1
- Feb 2013
- 10
XMT 304 Problems
02-04-2013, 09:27 PM #2
- Feb 2013
- 10
Nobody has any ideas?
02-05-2013, 08:14 AM #3
The Help 6 and Help 7 codes tend to point toward a buss capacitor imbalance. In other words, there are large electrolitic capacitors that should store about 325VDC on them and if there is a difference in this voltage amount, it can set the "Help 7" help code. Occasionaly, it can set the "Help 6" code as well.
As for the "Help 0" code, this one is most usually caused by a failure in the Auto Link circuit. So if the contactor inside the XMT does not get energized, it usually sets that help code. The contactor coil resistance would have to be measured to determine if this is an issue with just the contactors and/or the pc1 control board as well.
02-05-2013, 01:30 PM #4
OK 99% of the time Hep7 is a failed drain cap resistor on the output board
99% of the time Help 6 is a control board issue.
Help 0 is a failed contactor, and its not auto linking.
02-06-2013, 09:43 PM #5
- Feb 2013
- 10
Thanks for the input,
Spoke to a tech today and he told me to measure the cap's and see if there is a difference between them, apparently they should be between 50 mf of one another. no problem i thought, but my meter only goes to 1000 mf and then maxes out not the 1200 i need.
When I purchased the welder it had a new board installed, should have tipped me off, so hopefully that isn't the problem. Not sure which ones they are but after the unit is unplugged the cap voltage does drop slowly leading me to believe that the resistors are working. Cruizer, any way you could explain which resisters are the ones i'm looking for? Are they the rc3 and 4?
Thanks for any infoLast edited by meyer_frank; 02-07-2013 at 02:53 PM.
02-07-2013, 02:53 PM #6
- Feb 2013
- 10
Measured the Capacitors today, 2567 and 2537. Should theses be closer to 2700 like they are rated?
