    Default amuminum pipe bender
    Hey guys, Im looking to buy a pipe bender that will make 90's using 1.5" aluminum with NO creases. Any reccomendations.
    East Tennessee
    143
    Professional Auto Mechanic since 1974
    My own shop since 1981
    Cya Frank
    on a budget..........realistically
    Cave Creek Az
    1,050
    Get a Hossfeld, or clone. About $800 including a set of dies for what size you want. Try American Bender. I like mine and do a lot of tube bending with it. I don't do a lot of aluminum though.
    Oct 2012
    yuba city, CA
    58
    Default pipe or tube?
    Quote Originally Posted by westpoint View Post
    ....and you're bending pipe or tube?...(there is a difference)
    .....and parent stock is welded or DOM?
    ...and the CLR (centerline bend radius)...is?
    ....and the bend accuracy desired...is?
    .....and the wall thickness...is?
    ....and the type and grade of the 'amuminum'....is?
    ...and the 'NO creases' requirement allows for wall thinning?
    ....cosmetic appearance?
    ....any distortion?
    ....and the end use ....is?
    Addressing these questions on the front end, saves problems on the back end
    561
    Is it for ornamental/railing?
    Its for the t top on my boat. Dont need anadized ganna be powder coated.
    Dec 2004
    Maryland
    135
    Default Bender
    I see electrians bend aluminum conduit all the time with a Greenlee Conduit bender with no kanks.
    Lake of the Ozarks MO
    3,593
    I bend mine on a JD2 bender. Pro-Tools has about the same thing.
    I bend 1 1/2" sch 40 6063 T-4 up to
    180 degrees
    If you try to bend T-6 it will break unless you an anneal it.
    You have to get the Delrin following dies or it will scar the material beyond use.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
