Results 1 to 2 of 2
Thread: Dynasty 200
    Jan 2013
    Default Dynasty 200
    Can anyone tell me if the the new 200 dynasty well tig thin aluminum up to about .080 on 115v or does it have to be 220v. I have heard some say one thing and others say another. Thanks
    Aug 2010
    1,158
    Quote Originally Posted by SKIDOG View Post
    Yes indeed you can weld .080 alum.
    Calculating that you set your amps per .001" of thickness, you can set your Dynasty to 80 amps to start. You can pretty much weld all day at 100 amps without much risk of throwing a 20 amp breaker. Anything above that will start taxing the 115 volt breaker. I limit myself to 120 amps whenever plugged into 115volts.
    The default AC settings work pretty well for sheet alum. Helium can give you a hotter also when the chips are down.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
