Results 1 to 10 of 16
    Default will not get complete pen.
    Welding carbon steel pipe in 6g and I cannot for some reason get penetration all the way thru. Any advice? I'm runnin 100 amps with a 1/8 gap. Outside visual looks great just not penetrating all the way thru..
    Cave Creek Az
    794
    Need more info. Process, gap land, filler rod, number of passes etc.
    1/16 land, er 70, root pass.
    Tig btw
    Any advice would be appreciated
    May 2012
    chilliwack BC
    32
    Sry your root is 7018? If it is your amps a way high drop it to about 70 ( I know sounds low) and rotate the rod like your walking the cup with tig. And push it in there with good pressure and it should stack up inside
    May 2012
    chilliwack BC
    32
    Crap just saw you put down it was tig. Just jam that fillet rod in and watch your amps that seems a bit high
    Try slowing down a bit and shorten your arc some
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    Make sure it keyholes for ya before ya move forward. No keyhole, no penetration.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Ok y'all I really appreciate it, I'll be sure to try that.
