A lady found my web site from Craigslist. She has a very old special piece of wood barn siding. She wanted two names carved on it with date. The wood was falling apart and was warped and cupped. I had to wet it down and clamp it to get it flat enough to carve on my machine. After a lot of crap, I finally got it to work.
After I wet it down, I had to let it dry before cutting...while cutting...because the wood was so old and dry, surfaces pieces starting chipping off so I wet it again to soften the wood fibers. Well, at that point, it wouldn't cut worth a darn so I had to stop. Too many loose wet fibers. Then I thought what the heck to do. I then thought, let it dry again and give it a coat of spar urethane to glue the loose parts down and harden the frizzies. The next morning, I set the cutter down about another .020 and it cut well plus cleaned the urethane out of the low spots. What a pain. I didn't try anything like coating at first because they wanted the wood in its natural state. I called her and said what I wanted to do for it to cut well so that's it. Btw, I welded on the machine that did thisThe board is about 42" long
Results 1 to 6 of 6
Thread: Ot project
Hybrid View
01-30-2013, 03:57 PM #1
Ot project
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
01-30-2013, 04:04 PM #2
Thats pretty cool - must be an old barn board from grandpas place, huh? I know the old guy I bought my place from wanted some of the old barn boards to give to his grandkids and such....Good idea on the urethane!
01-30-2013, 05:17 PM #3
Member
- Oct 2011
- 40
wood art
Very very cool great job.
ARMOR
MOBILE WELDING&SERVICES
Trailblazer 302
X-TREME 12VS
Spoolmatic 30A
Millermatic 135
WeldCraft WPseries TIG torch
Smith oxy set.
01-30-2013, 10:40 PM #4
- Feb 2012
- Wa
- 320
Sounds like a dull bit/cutter head. Looks nice though in the end!
01-31-2013, 06:04 AM #5
Good thinking, that old wood is like cutting through playdoh.
Good thing it says May 4th, May 3rd is reserved for me, my wedding day.
01-31-2013, 06:59 AM #6
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
