    Jun 2008
    Florida
    135
    Default Any negative effects from magnetic torch holder?
    I was curious if the common magnetic base tig torch holder could actually cause any harm as far as welding goes, with its magnetic field messing with the torch itself? Is tungsten affected by magnetism? Or are there any steel parts in a tig torch handle that are magnetic? Just curious.
    Thanks,
    G
    Oxy/Ac Large Tanks
    Miller Swinger AC 180 (SOLD)
    Miller Syncrowave 250DX Runner with Pulser
    Aug 2008
    113
    Probably not going to inter fear but I would not stick it to the side of your machine
    Dec 2012
    64
    It will have no effect, no matter what. Even sticking to the power supply.
    Sep 2012
    London
    21
    Steve is right, there will be no negative effects from magnetic torch holder.
    Jun 2008
    Florida
    135
    I wouldn't be sticking it to my machine, just the welding bench top. I know magnetic fields within about 6 inches can cause stick and MIG welding arc issues but was more concerned with the tig torch and electrodes themselves. It's a pretty powerful magnet on one of those.
    Thanks,
    G
    Oxy/Ac Large Tanks
