Results 1 to 3 of 3
    Jan 2013
    Default Millermatic 250MP settings
    Hi Guys,
    I'm an amateur at welding, just do it for my pleasure so pl don't laugh
    I just bought this welder and I was wondering what is the difference in the Mode menu btw Weld and the last option: Schedul means? Yes I've downloaded the instruction manual already but its not clearly explained. Which one should I mostly use when welding? Thank's Guys
    2,634
    The last option is Dual Schedule- allows you to program the machine with 2 settings:
    1- For A- flip the switch on the gun to A and the machine outputs whatever parameters you programmed
    1- For B- Flip the switch to B etc etc.
    Just keep it in Weld Mode
    Jan 2013
    Thank's Dude lol I'll follow your advice....
