Results 1 to 3 of 3
    Jan 2013
    2
    Default Millermatic 250MP settings
    Hi Guys,
    I'm an amateur at welding, just do it for my pleasure so pl don't laugh
    I just bought this welder and I was wondering what is the difference in the Mode menu btw Weld and the last option: Schedul means? Yes I've downloaded the instruction manual already but its not clearly explained. Which one should I mostly use when welding? Thank's Guys
    Los Angeles
    2,908
    The last option is Dual Schedule- allows you to program the machine with 2 settings:
    1- For A- flip the switch on the gun to A and the machine outputs whatever parameters you programmed
    1- For B- Flip the switch to B etc etc.
    Just keep it in Weld Mode
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Jan 2013
    2
    Thank's Dude lol I'll follow your advice....
