    May 2011
    Bossier Parish La.
    540
    Default Wheels For A Truck Rack
    My truck rack costs me about 1 MPG to carry around on my truck. Since I don't use it on a regular basis I wanted to be able to take it off when not needed and put it back on when it is. I have a set of A-frames, but can't leave it there when it is not on the truck. The area is used for parking, and is also the entrance to the double doors on my shop, not to mention I may need to hoist something else besides the rack.
    I used 2, 5" pieces of 2.5x2.5x1/4" angle iron and 2 pieces of 2x2x1/4" angle and a piece of 5/8" rod for the axle for each one. I sandwiched a piece of 1/4" angle between the other angle already mentioned, and the rod on the other side. Then I welded the rod on both sides to both pieces of angle iron. This makes for a snug slip fit to the bed rail pieces, so no need for set screws to hold it on, gravity does just fine. I put them on at the balance point of the rack and I can move it around like a wheel barrow. I figure some of y'all might be able to use this idea for the same reason I needed it.
    wisconsin
    116
    Thats a great idea.Truck rack could use a coat of paint.
    May 2011
    Bossier Parish La.
    540
    Quote Originally Posted by kevhead63 View Post
    Yeah I know it could. I painted it in Sept 2001 after the 9/11 incident and haven't refreshed it since. That's when I was building it, and was wanting a flag for my truck but everyone was sold out, so I painted the rack like that. Don't know if I will repaint it the same or go with a solid color this time. That paint job takes a few days to do and is kind of labor intensive VS. a solid color.
    Default Literature Holder
    Brochures are advertising pieces mainly used to introduce a company or organization, and inform about products and/or services to a target audience.
    Literature Holder
