Often when cutting off larger thicker steel with an abrasive (made for steel) 14" cut off the sparks and cutting stop and the steel gets hot.
I can detect the the "blade" is hot but only for a very short time.
Even after the blade and steel cool several min. it will not cut unless I wait for a long period of time, about an hour it will cut again.
I know the problem is the blade cause if I put in a fresh blade I can cut immediately.
What is going on?
going to go try to finish the cut in a 3/16" x4"
Results 1 to 10 of 14
01-27-2013, 01:44 PM #1
- Nov 2010
- 38
Physics lesson needed.....abrasive cut off performance
01-27-2013, 02:05 PM #2
- Oct 2006
- Illinois
- 458
I have the same thing happen. The blade gets a glaze on it and it won't cut. Try cutting some thinner or light gage material to remove glaze.
01-27-2013, 02:33 PM #3
If you don't push down consistantly it helps. Like alternating between pushing down & letting up on the handle. I have also flipped the abrasive disc around. Just make sure it isn't directional. You can also try a lube while cutting. Sometimes I use wax (http://www.mcmaster.com/#lubricant-stick-wax/=l7zxs1) or wd-40.
Sorry can't give you the physics lesson.MM250
01-27-2013, 03:20 PM #4
When cutting flat bar in an arbrasive saw try cutting it standing up verses it laying flat, I would always keep steady pressure, If you let off in the midddle of a cut the steel hardens and when you start back you have to heat it back up again before it wants to cut.
I wouldnt put any oil on the blade ( You dont want it to deteriorate and shatter).
If your cutting it in a band saw then you want to lay it down flat.
01-27-2013, 03:47 PM #5
- Feb 2012
- Wa
- 314
Purchasing quality wheels is important too. I am yet to find anything that works as good as Sg Elastic products.
01-27-2013, 04:27 PM #6
- Dec 2008
- west edge of the RRV
- 65
The lower quality disks are especially bad. The grit glazes and stops wearing away, thus just making more heat. When I used to use a chop saw alot, I had a piece of spring steel that I would touch to the disk and break the glaze off so it would keep cutting.
01-27-2013, 09:47 PM #7
- Nov 2012
- Northern Arizona
- 268
I try to keep the surface area of the cut as small as possible. The example of flat stock works well for me. Also, c-channel I'll stand on end and I do that with smaller angle iron (1.5"x1.5"). "pulsing" the pressure helps and I try to keep the RPMs up on the blade. I have been using the diablo 14" abrasive cutoff blades and they have been decent. Readily available. I think part of it is just practice? Finding the fastest and most efficient way to cut without damaging the parent material.
Good luck.MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
01-28-2013, 05:04 AM #8
- Jul 2010
- 333
Those big abrasive wheel cutters suck. I hate em. I only use mine now if I can't cut the piece with either a Porta-Band saw or a small cutting wheel on an angle grinder...which means "almost never."
I think I'd rather try to chew through the cut with my teeth than use a 14" abrasive cutter.They take forever, they make a racket and they usually make a lousy cut.
01-28-2013, 05:23 AM #9
- Feb 2012
- 81
Seems like the long life blades are the worst for glazing try a fast cut blade the fast cut are getting harder to find I think the last one I got was at grainger.
01-28-2013, 05:55 AM #10
Second that, just like steel can be hardened, the grits on the wheel can get "hardened" Think of it more as using a hole saw through plastic. If you use a 3" hole saw to drill through 1" plastic with a lot of pressure and speed, you will melt the plastic, and once it gums up on the teeth, you will never cut until the teeth are cleaned.
I would just use another piece of metal and "clean" the wheel, and keep going. I never did try switching the blade around, that seems like a good idea.
