Results 1 to 5 of 5
    Jan 2013
    2
    Default Spool gun controller
    I have a Spoolmatic 30A spool gun and was wondering what I would need to run it off of a Lincoln Vantage 400
    Oct 2004
    Edmonton, Alberta
    6,763
    You would need a WC-24 and a Weld Alert adaptor ($225)
    Jan 2013
    2
    Thanks for the info. I have the wc-24 controller. I meant to ask what adaptor I needed for the Lincoln. Thanks again.
    Jun 2009
    Appleton, WI
    46
    My only question to using the WC-24 on the Lincoln Vantage, is that the WC-24 will need 24 VAC to operate. As far as I know the Lincoln will not have this, but maybe I am incorrect.
    I think you would want the WC-115A with contactor to use that spoolgun on the Vantage. (Miller #137546-011)
    Oct 2004
    Edmonton, Alberta
    6,763
    Our adaptor would be better, a it adapts that spoolgun to ANY welder having CV.
    It was originally designed to adpt the Miller to the Lincoln engine drive, however it was discovered that it wa real easy to adapt it to ANY other brand of CV welder.
    Magnetic mounted and simply plug and play.
