Results 1 to 6 of 6
    Dec 2011
    Illinois
    87
    Default braising question
    Here is my question guys, I have the diversion 180 im pretty sure I can brais with it just have not tried til now. My old neighbor friend brings me some solid brass wire (no flux) I fire up my diversion on DC and give it a wirl on some scrap and the minute I begin to add the rod it dont like it one bit! kinda flares up and goobers up my tungsten. I tell him it has to be the rod he says no, so where is the problem? Is there a special braising rod i need to use for this? The rod he gives me to try has no brand or info. wich sends up a red flag with me, however the little bit I did do showed some type of brass in it so at this point im to say the least. So any help on this matter would be great thanks in advance, Eric
    Dec 2011
    Illinois
    87
    No one, with any input on this?
    Aug 2010
    Los Angeles
    1,163
    The zinc in the brass is reacting to the arc. Try silicon bronze, as it is recommended in lieu of brass.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Dec 2011
    Illinois
    87
    Shovelon,Thanks for the info. I did not know that. I was hoping you would chime in with your wealth of knowledge I will try to round some up. Is there a preferred tungeston for this as well? Thanks again ,Eric
    Aug 2010
    Los Angeles
    1,163
    Quote Originally Posted by three turbos View Post
    I prefer red. Although most any but pure would work.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Dec 2011
    Illinois
    87
    Red is aready in the inventory, its actualy what I was using at the time so thank you again much appreciated.
