Thread: .052 overkill?
    Jan 2013
    Nebraska
    15
    Default .052 overkill?
    I'm using .052 solid core wire to weld 3/8 to 1/4 domex, always seem to get a little undercut no matter what I try, opinions on this please
    New Jersey
    779
    U can make that work....lower the voltage a bit and or raise the wire speed....let it freeze a little quicker...
    Default under cut
    How does your welding supervisor say to fix it. Just curious
    ARMOR
    MOBILE WELDING&SERVICES
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    WeldCraft WPseries TIG torch
    Smith oxy set.
    Jan 2013
    Nebraska
    15
    Thank you turbo, I have been running at 30 volts and just a hair above 4 ipm, Friday before I left work I turned my machine down to 28. I will raise the wire speed monday and let you know how it turned out. And actually right now we don't have a supervisor, and when we did he wasn't very knowledgeable on welding
    Default .052
    I bet if you look at your wire again you will see it's metal core not solid. Your numbers don't sound that bad to me. I would try changing your gun angle a bit and your travel speed.
    ARMOR
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    Smith oxy set.
    Jan 2013
    Nebraska
    15
    Thank you armor, and yes your right, its metal core wire, tri mark metalloy, made by Hobart brothers
    Jan 2013
    Nebraska
    15
    Thank you both for your inputs, I have been MIG welding for only 2 years now and just recently discovered this forum. I believe this is going to be a great tool for me.
    Default .052
    It's a great sight. You can get some great information on here. But remember it's free so always do your homework.
    ARMOR
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    Smith oxy set.
    3,650
    Quote Originally Posted by k2thab81 View Post
    Thats pretty common in a shop...Bob
