Results 1 to 10 of 11
Thread: average cost
    Jan 2013
    Default average cost
    I would just like the average ballpark cost of a three rail pipe fence; setting post, 10' apart, top rail is 48" high, the top rail and posts are 2 7/8" and the 2nd and 3rd rail are 2 3/8". Average cost per foot or hour?. Thanks
    561
    Are you asking about chain link?
    1,910
    Quote Originally Posted by go2building View Post
    No chain link just posts with a top rail, mid rail & lower rail. Sorry I can't help ya as I don't do this stuff everyday so someone who does probably knows a per foot price off the top of their head.
    Illinois
    632
    You may want to post thickness or gauge of pipe material. Tubing and schedule
    40 pipe makes a big difference.
    Alberta Red Deer
    373
    for the most part for a basic structural hand railing i quote $70 per foot
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    We are about $70/ft. 1 1/2"sch 40 pipe and posts. Finished with primer
    btw. Code requires our posts to be a max of 4'-0" apart max
    Jan 2013
    Quote Originally Posted by arc View Post
    Thank you for your reply.
    Aug 2004
    Milan Michigan
    1,808
    Posts 10' apart is to far I space 1-1/4" pipe at 5' on center or less and 1-1/2" pipe at 6'-8" max.
    Core drilled into concrete price primed 3 line if I'm doing 50' or more is approx.
    $ 70.00 per ft but goes up when doing less that 50'
    Oct 2012
    Neosho Mo
    79
    Default fence quote
    You are asking about more of a farm style yard fence correct? In southwest Missouri you could probably get that done for 16 dollars a foot. That is if you drive the post concrete would cost you more because it takes longer. That is figured with reject pipe. 2 7/8 & 2 3/8 on 8 foot centers
    Oct 2012
    Neosho Mo
    79
    Also I might add how long, you must charge more for short stuff because it cost to drive there and roll out your stuff. Also soft ground rocky ground and customer annoyance are factors to figure:-)
