Hi All
So my TB302 with a Kohler engine is doing its job but needs an oil change.
Oil and filter changed
Now it doesn't start. Turns over great.
Go over and top off the gas tank, it only took 6 gals.
I'm thinking either the "Low oil presure switch" or the Gas solenoid.
Can't find either of these but I'm not sure what they look like.
What are your thoughts
Hay Cruzier you got your ears on?
Thanks in advance.
Results 1 to 2 of 2
Thread: TB302 start problem
01-24-2013, 03:33 PM #1
- Nov 2008
- Colorado Springs
- 272
TB302 start problem
Live Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
Hypertherm PowerMax 1000
20" x 40" CNC Mills (2)
16" x 60" engine lathe
65 Ton edwards iron worker
3/16' x 24" power slip roll
16' power feed mitering bandsaw
and other fun toys
01-24-2013, 04:09 PM #2
- Nov 2008
- Colorado Springs
- 272
Found It!
We pull the unit off the truck so we could really see everything.
Well the oil drain hose had a wire wrapped around it and we broke that wire when we pulled the hose to drain the crankcase.
Spliced it and it started right up.
OK a little embarrassed
But hey we found it
Live Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
and other fun toys
