Results 1 to 2 of 2
    Nov 2008
    Colorado Springs
    276
    Default TB302 start problem
    Hi All
    So my TB302 with a Kohler engine is doing its job but needs an oil change.
    Oil and filter changed
    Now it doesn't start. Turns over great.
    Go over and top off the gas tank, it only took 6 gals.
    I'm thinking either the "Low oil presure switch" or the Gas solenoid.
    Can't find either of these but I'm not sure what they look like.
    What are your thoughts
    Hay Cruzier you got your ears on?
    Thanks in advance.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Nov 2008
    Colorado Springs
    276
    Default Found It!
    We pull the unit off the truck so we could really see everything.
    Well the oil drain hose had a wire wrapped around it and we broke that wire when we pulled the hose to drain the crankcase.
    Spliced it and it started right up.
    OK a little embarrassed
    But hey we found it
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    and other fun toys
