Can anyone address a concern I have on safety.
I'm putting fire proof welding curtains up in garage,
cement floor, cement outside wall.
My concern is the ceiling - typical peaked plywood roof with
a few 2x4 trusses 10 feet high.
Should I put fire proofing up there as well ?
Using a passport plus.
Please advise,
Thanks, Stu
Results 1 to 10 of 14
01-24-2013, 02:09 PM #1
- Dec 2012
- 27
Safety Question - sparks/wood ceiling ?
01-24-2013, 02:54 PM #2
- Nov 2012
- Northern Arizona
- 275
As long as your welding at shoulder height or lower I don't see problem. Gas shielded solid wire?
A lot of it is just keeping your SA up.MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
01-24-2013, 03:22 PM #3
- Dec 2012
- 27
Using the CO2 internal bottle.
May get a bigger bottle in a while - see how it goes.
Just doing tack welds for armatures.
Thanks, Stu
01-24-2013, 04:02 PM #4
- Sep 2007
- Medford MA
- 525
On the other hand, if the shop already is torn apart, etc, why not add it now if you can?
01-24-2013, 04:31 PM #5
- Oct 2006
- Illinois
- 475
I would say get a couple of fire extinguishers . If gasoline is stored there invest in a safety can instead of plastic containers.
I don't think your gonna have sparks going up seven feet above your welding table. If you are concerned hang a blanket above the table.
01-24-2013, 04:36 PM #6
Fire extinguishers are a must no matter what. My shop is pretty good sized - 40 X 60 with 14' ceiling, and I dont weld or cut on anything before leaving. Even then I turn the lights off and look around in the dark to make sure theres nothing smoldering. Another good reason to have a clean shop
01-24-2013, 08:38 PM #7
- Dec 2012
- 27
No gas or flammables in garage,
just wondering about sparks going up to ceiling.
Two new fire extinguishers in place.
Thanks, Stu
01-24-2013, 08:40 PM #8
- Dec 2012
- 27
01-24-2013, 09:27 PM #9
- Feb 2012
- Wa
- 327
I would not worry with ceilings that high. I frequently weld in an area with 8' ceilings and there is zero spatter trails on it.
01-25-2013, 05:52 AM #10
- Dec 2011
- 247
We try to go back and check for fire/problems three to four hours after the end of operations for the day. We have found a wall on fire and various things smouldering. Guess I need to clean up the shop. Also cooling pumps in trouble(not welding equipment) and things left on that we were told had been shut down. My experience is that a few hours will give a problem time to get going enough to be noticeable.-Meltedmetal
