Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Default Press brake - Opinions
    I bought a HF 20T press. My main use for it will be bending flatstock. My standard most common size will be 4x3/8" flatstock @ 90deg. I have attached a drawing of my plan. It is designed with what I have here in my shop.
    Any ideas/modifications will be appreciated.Press brake.jpg
    Attached Files Attached Files
    Salem ,Ohio
    3,655
    Cool
    Looks like it will work. You might want to make your top punch tighter than 90 degrees like 80 something. Mine is 42 degrees on a side...Bob
    northern NJ
    1,568
    Bob is correct, you want your top & bottom dies tighter than 90 degrees or you will have trouble getting your pcs. to 90.
    MM250
    RCCS-14
    So both the top and bottom @ 80 deg?
    Salem ,Ohio
    3,655
    Cool
    Quote Originally Posted by aaronobrien View Post
    No just the top. The bottom can be 90...Bob
    Okay, so just the top @ 80 deg or so. Bottom can be 90deg....
    Does the punch have to be hardened? If so, what is the proper process for it?
    Salem ,Ohio
    3,655
    Cool
    Thats up to you. How many parts you going to make? A zillion then yes. If the bottom center wears just regrind or recut it to suit. Just my thoughts...Bob
    thanks bob,
    Over the course of a year, ill probably bend 100-200 pieces. possibly more if it works as well as it seems like it should.
    northern NJ
    1,568
    For air bending which is what you plan on doing the bottom should be less than 90. The 4 way die on the Cincinnati I used to run was 82*. The top should be sharper than 90 also. This lets you over bend slightly to compensate for spring back.
    I can't see how thick a plate your top die will be but I would use 1".
    MM250
    RCCS-14
    Sep 2012
    seaford de
    335
    I used angle for the top and bottom on my iron worker brake and it over bends a 90 every time if your not careful.
