Results 11 to 17 of 17
    Dec 2009
    722
    Maybe turn your wire speed down a tad. Watch how you hold the gun make sure the nozzle is 90 degrees to your work or you will blow spatter to the back side. I weld with .045 gas flux core everyday....Bob
    Why do you use .045, is it thin material? I use 1/16 most of the time. I find little use with 045 if the material is 1/2 or thicker.
    Aug 2012
    Hermiston Oregon
    297
    U ain't suppose to use gas with flux coref wire. It aint dual shield.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Default Flux core spatter
    Uh ya it is dual shield
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Quote Originally Posted by eecervantes83 View Post
    Really ???
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Its called dial shield because of the gas acting as the second shielding agent... Hence the name dual shield. Most flux core is gas shielded actually.
    Alberta Red Deer
    373
    tweak ur settings a little bit. ie. up the voltage a bit or knock the wire down a little to keep the spatter down. 9 times out of ten you will find a roll of dual shield on the wire feeder rather than gas-less flux.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    3,972
    Quote Originally Posted by Daniel View Post
    My tanks i weld are 3/16" and up. I use a MM252 but the other guys are running Miller 300's and they use 1/16" wire...Bob
