Results 1 to 10 of 17
    Default Flux core spatter
    I'm running 100% CO2 at this time so i know I'm gonna get a ton of spatter. But I'm doing horizontal and I'm having to clean my nozzle/contact tip after every 2 beads or so (only about 16"worth of welding) because it sticks to the metal and messes me up. I haven't played with flux core very much. Am I doing something wrong or is this fairly normal?
    Jul 2010
    Salem, NJ
    298
    Nozzle dip/flux whatever they call it. It works wonders.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    What brand and type of wire are you using. Most brand name wires like esab and lincoln offer a low spatter wire.
    What angle are you holding your nozzle at in relation to the work piece? That will make a huge difference in the amount of spatter that comes off the arc.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    1,928
    Check your parameters as you should not be getting "a ton of splatter" with gas shielded flux core wire.
    If this is innershield wire (flux core no gas) then you shouldn't be running gas with it & you most likely should be running dc -.
    Jan 2012
    Coos Bay Oregon
    22
    stay in your puddle, check voltage, gas flow will be 25-35 cfh depending on wire manufacture. Most FCAW-GS runs DCEP.
    3,972
    Maybe turn your wire speed down a tad. Watch how you hold the gun make sure the nozzle is 90 degrees to your work or you will blow spatter to the back side. I weld with .045 gas flux core everyday....Bob
    Aug 2012
    Hermiston Oregon
    297
    I do a lot of welding with flux cored wire. And can tell you from experience you should be getting very little splatter if set up correctly.
    What machine are you running?
    What direction are you welding ?
    What settings?
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    I'm running a miller...um... Not sure what model haha I'll have to check. But 25.5v at about 300 ipm. Gas at 25-30 cfh. My gun angle is mostly a drag with a slight upward angle.
    Oh and with Hobart 71T-1C
    Dec 2009
    722
    Try 26.5 to 27 at around 400 for wire speed.
