Results 1 to 10 of 11
    Default Need wire that is compariable to 7018 stick rod and which gas to use with it?
    Need to weld thicker steel on bucket edges.
    Have used 7018 stick rod, want to try Mig welding it what wire is similar to 7018?
    Can I use straight CO2 gas and not Argon CO2 mix gas with the strong wire?
    Will the results with straight CO2 gas be the same as with the Argon/CO2 gas that is the strength and appearance of the weld?
    Jul 2008
    Flin Flon & Creighton area
    191
    Default what type of buckets, and exactly how thick of material?
    Are you repairing buckets that have been in service ? MIG may not be the best choice, Flux-cored may be a better solution, depending on the variables. I have recent experience working for a company that rebuilds mining scoop-tram buckets, that are usually at least half inch thick material at the very minimum,and usually much thicker, and have extensive armoring and abrasion resistant plate, and wear bars added. Hardwire Mig is not forgiving for this type of material given the possible contamination given from underground mining operations where sulfur in the ore is present. It gets into all the cracks and even the actual porous structure of the steel itself. Unless you can sandblast or have an infinite supply of grinding wheels you are wasting your time. The best and fastest process is probably dual-shielded flux cored welding. This wire has flux built in like 7018 and uses a gaseous shield, usually by C02 or a argon co2mix. There are numerous options of what brand size and type of gas to use. We use ESAB 710x wire in .045 and 1/16 with 100% C02 with excellent results in all positions using Spray transfer and fast deposition rates. You cant even compare the amount of metal you can put down using fluxcored to the rate of 7018. It is awesome. There are many brands of wire , this particular wire shines the best ,or so we have found. Other wires such as lincolns 71elite or Drahtzung Stien megafil are the next bestin that order. ( sorry for the shameless plug of a brand , but its that good! ) this wire and gas combo actually also surpasses a 70,000 tensile weld as well , and welds AR or QT400 steels very easily with excellent results. Use the proper procedure and you cant go wrong.
    End of commercial
    Hope this helps!
    I have a welding addiction
    1,565
    From my own experience I have used ESAB 7100 ultra with co2 gas on many bucket repairs/rebuilds with good results. I have not checked out the specs with 7018 side by side.
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    I will definitely agree with MMW. I have used ESAB 7100 Ultra w/ 100% CO2 for a few years now on my heavy equipment repairs and have had nothing but good to say about it.
    It is also very similar to a 7018 in tensile and yield strength. The only thing which differs significantly is the charpy v-notch value. Also, the 7100 is seismic certified if that can apply to you. I don't think you can go wrong with the 7100.
    I have never used it, but the 710X wire is also comparable with the 7018.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    3,648
    I run the 710X ESAB .045 wire with CO2. Great wire...Bob
    Aug 2004
    Milan Michigan
    1,418
    Flux Core is a good process but to answer your question The wire equal to 7018 is ER70-S6, I use to run 75% argon 25% co2 but swithed a couple of years ago and now run a 90/10 gas mix.
    northwest Pa
    76
    Another user of Esab 7100 Ultra with co2. You can put down alot of metal fast.Slag cleans up easy too.
    My shop used to run flux core ESAB 710x. We made the switch to Pulsed Mig. There is no comparison to flux core, and stick welding is left like a lost hub-cap.
    Jeff Lund
    Lund Machine Works
    www.lundmachine.com
    Oct 2012
    5
    XLR 8 from Hobart runs nice but it is a self shielded wire, for a gas shielded Hobart XL 525 runs great on a mixed gas. They both run excellent out of position and give you great mechanicals
    asheville n.c.
    595
    072 232 wire no gas needed
