I am looking at buying a cheap 8in bandsaw with a cooling oil setup on. My question is is there a water soluble cutting oil that I can use that won't freeze? Or something I can do to the cutting oil that will make it not freeze?
Results 1 to 10 of 18
Thread: Cutting fluid that won't freeze?
01-21-2013, 06:42 PM #1
- Mar 2012
- 20
01-22-2013, 06:23 AM #2
Just get the RV antifreeze and add to your coolant as you would your car. I say the RV stuff because it is more "enviromentaly correct"
01-22-2013, 08:26 AM #3
- Mar 2012
- 20
Won't the antifreeze cause the oil to separate from the water? That is what I was told by a couple of guys out this way.
01-22-2013, 08:49 AM #4
- Oct 2006
- Illinois
- 458
Check with manufacture of band saw if required. I know ELLIS saws do not require and cutting fluid.
01-22-2013, 09:39 AM #5
I just stir it from time to time, it never has done me wrong.
01-22-2013, 10:29 AM #6
- Mar 2012
- 20
This saw needs it. The manufacturer just replied and told me to put it in a heated shop. I will only have a non heated trailer for it to live in. I will try the rv antifreeze idea if it hasn't been a problem for you guys. What ratio should I run it at with soluble oil?
01-23-2013, 08:44 AM #7
can pick up a pan heater for a car. they are magnetic and work really well just put on the out side of the tank and your good to go.
heres what i use on my hydmech 20
https://www.acklandsgrainger.com/AGI...de=TMR340-0017trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
01-23-2013, 09:05 AM #8
- Mar 2012
- 20
I was thinking about that but I would have to let a generator run 24x7 to power it. I don't have the luxury of a shop with power or heat either.
01-23-2013, 11:30 AM #9
- Jan 2013
- 2
Arc, how big is your coolant tank? This is a very good thread, because I'm sure there are plenty of us that only heat our shops when we work in them. What brand-type of coolant do you use?
01-23-2013, 12:51 PM #10
i use MOBILCUT 102 in our saw and for most drilling applications. the tank on the saw holds about 3-4 gallons.
trail blazer 302
hypertherm plasma
millermatic 251
o/a torches
