Results 1 to 10 of 18
    Default Cutting fluid that won't freeze?
    I am looking at buying a cheap 8in bandsaw with a cooling oil setup on. My question is is there a water soluble cutting oil that I can use that won't freeze? Or something I can do to the cutting oil that will make it not freeze?
    Jul 2010
    Salem, NJ
    280
    Just get the RV antifreeze and add to your coolant as you would your car. I say the RV stuff because it is more "enviromentaly correct"
    Won't the antifreeze cause the oil to separate from the water? That is what I was told by a couple of guys out this way.
    Illinois
    622
    Check with manufacture of band saw if required. I know ELLIS saws do not require and cutting fluid.
    Jul 2010
    Salem, NJ
    280
    I just stir it from time to time, it never has done me wrong.
    This saw needs it. The manufacturer just replied and told me to put it in a heated shop. I will only have a non heated trailer for it to live in. I will try the rv antifreeze idea if it hasn't been a problem for you guys. What ratio should I run it at with soluble oil?
    Alberta Red Deer
    373
    can pick up a pan heater for a car. they are magnetic and work really well just put on the out side of the tank and your good to go.
    heres what i use on my hydmech 20
    https://www.acklandsgrainger.com/AGI...de=TMR340-0017
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    I was thinking about that but I would have to let a generator run 24x7 to power it. I don't have the luxury of a shop with power or heat either.
    Jan 2013
    Arc, how big is your coolant tank? This is a very good thread, because I'm sure there are plenty of us that only heat our shops when we work in them. What brand-type of coolant do you use?
    Alberta Red Deer
    373
    i use MOBILCUT 102 in our saw and for most drilling applications. the tank on the saw holds about 3-4 gallons.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    o/a torches
