My Miller 211 has the following specs:
Rated Output
150 Amps at 23.5 VDC, 30% duty cycle (230 V)
Welding Amperage Range
30 - 210 Amps
Before looking at this in detail I would have thought these two values would have been the same on the top end.
Can someone explain these for me? Thanks.
Results 1 to 4 of 4
Hybrid View
01-21-2013, 07:07 AM #1
Member
- Jul 2012
- 86
Rated Output vs Welding Amperage Range
Miller 211 MVP
Hobart StickMate LX 235
Lincoln AC 225
CutMaster 42
01-21-2013, 07:12 AM #2
Rated outputs are your typical everyday use. You could get the 210 amps out of it, but your duty cycle will drop to 10% or below.
JIM
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
01-21-2013, 07:16 AM #3
Member
- Jul 2012
- 86
Thanks Jim. I figured it was something like that but couldn't put it in words. :-)
Miller 211 MVP
Lincoln AC 225
CutMaster 42
01-21-2013, 07:25 AM #4
No problem. Glad to help.
JIM
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
