Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Railing
  1. #21
    Oct 2012
    Neosho mp
    32
    The one I'm starting has some pretty bad concrete some old some new some with more fall than other. For the most part I'm gonna have to build it in place. Would you suggest dipping the weld plate in primer before bolting down?
  2. #22
    Raymore Missouri
    1,906
    Primer is designed to provide "tooth" for the paint to adhere to. I would at least prime and paint base plates. If not, they will rust staining the concrete. Not very pretty. I have even thought about rubber spacers the same size as base plates.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
